Home » Language IDEs » Java Development Tools (JDT) » how to install "import java." and "import javax.
how to install "import java." and "import javax. [message #1797857] Wed, 07 November 2018 09:14 Go to next message
Tried to import a java.bufferreader and filereader and IOexeption. but none of them come up. Did I forget to install a package of some sorts? If so, how do I go about installing them (step by step instructions preferred because I am new to java and eclipse)AkinatorXender Kik
or
Are they already installed and are no longer go by those statements in java? If so, what are the new statements?
[Updated on: Wed, 07 November 2018 14:53] by Moderator
Re: how to install "import java." and "import javax. [message #1797939 is a reply to message #1797857] Thu, 08 November 2018 18:16 Go to previous messageGo to next message
Two ways to find out:
- instead of typing "import java." (which probably gives too long a list to actually find anything?) type "import BufferedReader" and then hit Ctrl+space
- use the Open Type dialog (Ctrl+T) and use all kinds of partial patterns to locate the type you need
Hint: those types don't live in package java, but in other packages that just start with "java.", like, e.g., "java.io".
Re: how to install "import java." and "import javax. [message #1850632 is a reply to message #1797939] Thu, 10 March 2022 23:53 Go to previous messageGo to next message
Did you mean java.io.BufferedReader etc.?
gb whatsapp
You could also try typing "import BufferedReader<Ctrl+Space>" i.e., without *any* package prefix.
HTH
[Updated on: Wed, 06 April 2022 04:09] by Moderator
Re: how to install "import java." and "import javax. [message #1852380 is a reply to message #1850632] Thu, 12 May 2022 23:14 Go to previous messageGo to next message
Harry Callum wrote on Fri, 11 March 2022 04:53
Did you mean java.io.BufferedReader, etc.?
yo whatsapp
HTH
I have tried this, but it's giving me an error.
Edit: It was solved!
[Updated on: Wed, 20 July 2022 04:39] by Moderator
Re: how to install "import java." and "import javax. [message #1852394 is a reply to message #1852380] Fri, 13 May 2022 11:17 Go to previous messageGo to next message
Ryan Wilson wrote on Fri, 13 May 2022 05:14
HTH
I have tried this but it's giving me an error.
Do you care to share what error you get? (remember that we don't see your screen)
Re: how to install "import java." and "import javax. [message #1856205 is a reply to message #1852380] Sun, 27 November 2022 00:03 Go to previous messageGo to next message
Ryan Wilson wrote on Fri, 13 May 2022 03:14
aero whatsapp
HTH
yes, it's fixed now I faced it long ago but no issues now.
Re: how to install "import java." and "import javax. [message #1856601 is a reply to message #1850632] Fri, 16 December 2022 13:29 Go to previous messageGo to next message
HTH
Didn't understand "Without package prefix" can you little bit explain.
Re: how to install "import java." and "import javax. [message #1856792 is a reply to message #1856601] Tue, 03 January 2023 01:25 Go to previous messageGo to next message
Not putting any package information in there, writing only "import BufferedReader", and then striking Ctrl+Space.
Re: how to install "import java." and "import javax. [message #1858494 is a reply to message #1856205] Wed, 05 April 2023 02:51 Go to previous message
islan tani wrote on Sun, 27 November 2022 05:03
HTH
Glad to hear your issue was resolved. Can you share what the error was and how you fixed it? It will help me facing similar problems.
Previous Topic:code style (and auto formatting) not working
Next Topic:java.lang.Error: Unresolved compilation problems:
Current Time: Sun Jun 29 08:37:15 EDT 2025
Powered by FUDForum. Page generated in 0.13642 seconds
